Results 1 to 8 of 8
Thread: How Dumb Am I!? ^_^ Dead A4000D
  1. #1
    Lazy Gamer Frederic_Freakazoid's Avatar
    Mar 2012
    United States
    Wisconsin
    20 (100%)
    Default How Dumb Am I!? ^_^ Dead A4000D
    So.. years ago (Link) I had gotten some great feedback regarding the RTC/Battery area of my dead A4000D motherboard. The problem is, I don't think the one thing people (including the late great Glen) kept pointing out was ever addressed (even though I'd kind of said it was over a year later). Can someone tell me specifically the traces that obviously need repair?
    I think I psyched myself out, to think it wasn't the problem, by testing with a multimeter, per some guide, but not actually knowing what settings constitutes a correct signal. Plus I am now way more confident with soldering/desoldering than I was back then.
    Exhibit A - "before"
    Exhibit B - "after"
    "Progress is being made if each mistake you make is a new one."
  2. #2
    8 Bit Dreams DjCook's Avatar
    Apr 2016
    Germany
    Bavaria
    39
    28 (100%)
    need also remove chips and clean under them
    Retro computer hardware & repair in Germany
  3. #3
    CrazyBob's Avatar
    May 2013
    The Netherlands
    Limburg
    113 (100%)
    Yep, what DjCook is saying is correct... I had a similair repair:
    Measure all via's in that area, also the ones underneath the simm-sockets...
    => Commodore A600HD/40 <=
    3D Amiga Gotek frames: http://www.thingiverse.com/_CrazyBob_/designs
  4. #4
    vibros's Avatar
    Sep 2009
    Italy
    Emilia-Romagna
    101 (100%)
    Hello,
    ...and be prepared to remove the simm sockets, because leakage from battery can affect this area under the sockets.
  5. #5
    Mar 2012
    United States
    Wisconsin
    20 (100%)
    *nods to all of the above* I just figured since people told me repeatedly (made embedded link obvious above), just from those pictures 4+ years ago, that I needed to repair traces, that something was glaringly obvious. Such as the bit of puffy gook to the left of the battery's spot in the "before" pic. *Somewhere* I had even read that a specific trace could cause boot issues (Edit: here it is), but for the life of me I can't find that article online again. I may first just tin those traces. I love all the resources available online (Edit: rereading them just makes me feel even more dumb for not trying any of this repair sooner).
  6. #6
    CrazyBob's Avatar
    May 2013
    The Netherlands
    Limburg
    113 (100%)
    I'm not sure what your approach is? Just tinning the 'obvious' traces is most probably not going to work.
    Total cleanup and measurement would be the best approach...removing chips (other components like SIMM socket and resistor array) and measuring all via's and traces in that affected area.
    One other thing, the acid from the battery and the capicators can get between the PCB layers, which is the white discoloration of the green PCB (4 layers for this board).
    Therefore it would be wise to measure the whole trace instead of short sections...
    Having said that, good luck with the repair and I really hope you can get it to work
  7. #7
    Mar 2012
    United States
    Wisconsin
    20 (100%)
    So far my approach is ask questions every 3-5 years online, get inspired, then ultimately do nothing.
    Thankfully I DO have some occasional free time now where I won't be interrupted by a (former) wife/gf and/or daughter.
    I DID see this Amiga get to the insert floppy screen once, then I bumped it, so I'm hoping a broken trace is the only issue.
  8. #8
    vibros's Avatar
    Sep 2009
    Italy
    Emilia-Romagna
    101 (100%)
    Hello,
    i do not know what you mean, but please, watch the picture:
    under U850 near BT176 there are three VIA that are the major cause of instability when an A4000D is affected by leakage of acid from BT176. Another issue can be the impossibility to use the full AGA chipset.
    Regards
    Stefano
  1. Sold Dead A4000D motherboard
    By CrashMidnick in forum Amiga
    Last Post: 29th October 2015, 10:10
  2. Sold Dead A4000D rev B motherboard
    Last Post: 21st September 2015, 20:17
  3. Closed Dead and/or gutted A4000D in the USA
    By orb85750 in forum Found Archive
    Last Post: 18th March 2011, 18:12
  4. Closed A3000 parts & A4000D dead MoBo
    By Bokassa in forum Found Archive
    Last Post: 7th February 2011, 13:42
