Sold Amiga A2000, 030 , 8mb ram , 1GB scsi,
Sardine
Staff member
Staff Moderator
Merseyside
Here is an Amiga A2000.
I forgot to take photo's of the board but its a Rev4.5 with a little leakage from the battery (Removed).
NO 68k CPU, (I broke a pin off the CPU trying to fit an IDE card, I can include the CPU and the pin)
Replacement 68000 CPU Fitted and tested
works and boots every time without issues.
GVP Impact A3001 030@25mhz with 68881 FPU, NO RAM. (so performance is reduced)
GVP HC+8 fully populated with 8mb ram and a 1gb scsi drive.
Kickstart 3.1
1MB Chip ram
ECS Agnus and ECS Denise
the key wasn't missing off the keyboard when I stored it. ive took the place apart looking for it, gutted...
the FDD is an recent amigakit item, the cable is off a PC so thats why you see DF1:?? but works no issues.
I tried another FDD and a HXC as DF1: and they work no issues so its the Cable.
the Plextor SCSI CD-Rom works no issues.
nice clean clear picture.
The Opalvision card I'm bundling with the system, it will plug into the Video slot but the back plate suggests its not for an A2000 ??
anyway assume not tested and bundled Free. (This is not an RTG, its a 24bit graphics/animation Addon).
due to the weight Pickup is prefered but I will ship
£275 (Was £325) + P&P,, if you collect its yours for £250
Well, I am not asking for a split, but...
Any chance to get original disks for the opal vision??
@BLINDGERMAN
I think.i.have some
I'll check tonight and if I have you can have them
Knowing the A3001 well, is it just the front board of the 2-board sandwich? Probably. The first A3001 board I owned was just the CPU card (Rev 4) and no FPU (added a 68881, then a 68882 later), but they all came with full 030's in that era, so maybe a jumper mis-set on it?
I know the CPU board could also be set for early German A2000 use (& pull the 68K) settings, or in this case a bad 68K gets bypassed in the B2000, hence the function without the 68K chip in the system.
Although I'm not interested (geography, just to start), it's not a bad system.
its the 50mhz version (fitted with 25mhz 030)
I need to look at it again,, it has "50MHZ" in white on the pcb suggesting a version II but running a 25mhz cpu (i think my eyesight aint the best)
it needs the hard to find Ram32 or Ram8 board to add 32bit fast ram.
The stenciled '50Mhz' only implies the last rev (#8, IIRC) of that CPU card, but it has no limiter on the actual CPU speed used. The CPU board, used alone, it can support any clock speed 68030 CPU (PGA) and 881/882 FPU. Because it's the last of that series, it's best mated with the RAM32 memory board also made at the time, although the RAM8 should work with the right CPU clock (25Mhz is lowest common denominator, so any should work at that speed) front board. When mated with a memory card, the memory card's settings and parts determines the CPU board's max clock speed that will work with it, and the memory configurations available.
I can explain the more complicated memory memory card situation if someone wants it. They are rare, but also low-demand, and I have seen them occasionally listed elsewhere. The CPU boards were >95% of the time sold with the memory card. I was one of those <5% back in early 1989 that bought only the front card. Such is as a poor college student could afford.
I'd would be iterested in that 8 MB ram ....
perchanche do you sell only them ?
Bye bue Fabrizio
Asking or hinting for a spilt is against the rules and probably not a good idea on a moderators thread :LOL:
Interested for a friend (Next in line)
Think he may be able to do local Pick up too
Looks like sanxion is pulling out
tim pm’d
