Page 1 of 40 1234511 ... LastLast
Results 1 to 10 of 400
Thread: 68030 TK - Another accelerator card for Amiga A500/A1000/A2000 designed by Matze (aka Matthias Heinrichs)
  1. #1
    8 Bit Dreams DjCook's Avatar
    Apr 2016
    Germany
    Bavaria
    42
    189 (100%)
    Default 68030 TK - Another accelerator card for Amiga A500/A1000/A2000 designed by Matze (aka Matthias Heinrichs)
    Ladies and gents,
    68030TK +64MB Turbocards are available, feel free to get
    a fastest 030 Accelerator designed and built in Germany NOW!
    UPDATE 26.07.2020
    we are glad to report that testing and adjusting phase of the 64MB expansion is over,
    we can ship You a well known 68030TK accelerator card designed by Matthias Heinrichs (aka Matze, Germany) now!
Name:	2020-07-28 22.00.46.jpg
    some of You already got this accelerator card with 4MB expansion, they can proove this is the fastest Accelerator in it's class available atm,
    Now we are back with 64MB version of it, and we are happy to report that this card is working on A500, A1000 and of course on A2000 too!
    Even more, it was designed as a part of expanded system, where RTG, Flicker Fixer, SCSI Devices, and other Expansions are united in one system!
    Of course it's still a hobby rather than a commercial product, so everyone with soldering skills is welcome to build these,
    Sources are available at: https://gitlab.com/MHeinrichs
    (Free for non commercial reproduction!)
    FAIR WARNING:
    There are some Zorro bus related issues on rev.4.x A2000 machines,
    this is rather rev.4.x and not accelerator related, hence accelerator will probably not work in CPU Slot
    As always, there are some important things You need to check before installing a new card:
    Most important thing here is PSU - it need to be in good shape (recapped)
    heavy 2,5A (A500) PSU version will probably be too weak and doesn't work
    do voltage mesurement (while system is on) on CPU socket, should be not less than 4,8V!
    CPU socket need to be clean and should make good connection to the board
    in some cases additional power & GND cables are necessary to be connected to the ram board
    Also Your Amiga need to be in good shape (recapped) - most caps are dry 35 Years after production date
    two big Caps near PSU Socket are most important!
    Also boards need a 3D Printed cover on the connector that acts like a shield
    (also piece of foil wrapped in a paper can do the trick)
    Options available:
    1) 68030TK + 64MB (card only, NO CPU) 155 Eur
    2) 68030TK + 64MB (card only, EC type CPU) 175 Eur
    3) 68030TK + 64MB, A500 / A1000 Set (EC type CPU) Relocator, CF Card adapter, Flat ribbon extension 190 Eur
    4) 68030TK + 64MB A2000 Set (EC type CPU) CPU Slot Card, CF Card adapter, Flat ribbon extension210 Eur
    Upgrade
    from 4 to 64MB:
    Unfortunately TK needs some resitors to be changed and Firmware (Lattice cpld) need also be reprogrammed
    Once this is done - You are ready to use TK card with 64MB RAM board - 70
    See correct resistor values here:
    http://www.amibay.com/showthread.php?99425-68030-TK-Another-accelerator-card-for-Amiga-A500-A1000-A2000-designed-by-Matze-(aka-Matthias-Heinrichs)&p=965857&viewfull=1#post965857
    or:
    You can also send Your 68030TK card to me,
    will gladly swap resistors and reprogram and do a full test
    Please send PayPal payments as "friends & family" or add 4% PayPal fee.
    Due to the cost of this expansion, shipping it tracked and insured only
    Shipping in Germany is 4,99
    Other Countries 25
    Also offered for sale elsewhere.
    FAQ:
    Q:
    Will this card work on the A500 and /or A500+?
    Sure, works fine, however a relocator board is needed to fit keyboard in place
    Q: Will this card work on the A1000?
    A: Yes, it does, however
    default A1000 roms can't work on 68030 CPU,
    because of that
    kickstart adapter is needed.
    WARNING! Installation reguires some soldering!!!
    Q: Will this card work on the A2000?
    A: Sure, it was tested on rev.6.x and is fully functional! FAIR WARNING: may or may not work in CPU Slot on rev.4.x, runs nice in 68k socket though
    Q: Will this card work on CDTV?
    A: No, this card will not fit inside an unmodded CDTV, sorry
    Q: Is the relocator necessary to use this card?
    A: Yes, it's really necessary to be able to close standard A500 case,
    to relocate accelerator to right position and add KS ROM on A1000
    and to be able to install it in CPU Slot on A2000.
    Q: What IDE device can I use?
    A: You can use CF Cards and real HDD Drives of course
    Q: Do i need to buy a CPU with MMU?
    A: No, this isn't necessary since this accelerator has it's own boot rom - IDE Speed is very fast.
    Q: Will this Accelerator work with KS 1.3?
    A: No, this Accelerator has 64MB ZorroIII FastRAM,
    KS 1.3 can't handle this amount of RAM,
    You need KS 3.1 or 3.1.4
    Q: Can i upgrade my existing 4MB to 64MB RAM card by swapping out ram chips?
    A: No, this isn't possible 64MB RAM card is totally different .
    Q: Will this card work on Atari STx?
    A: Nope, this card was designed to be used in Amiga computers, however source code is well documented,
    feel free to write Atari Firmware for it!
    JanHolbo - TK+64MB - PM Sent
    Haxxy - TK+64MB - Paid
    voyager2
    - Upgrade - PM Sent
    chatopirulo - 2x TK+64MB Sets A500+A2000
    hlide - Upgrade
    bandan - 64MB
    rmzalbar - Upgrade
    Vypr - Upgrade
    dallyis - Upgrade
    Hal - Upgrade
    PrzemasIII - Upgrade
    knightstone - Upgrade
    klacko - TK+64MB
    Ollis - TK+64MB
    ori1a - Upgrade
    zJark - TK+64MB
    upsnowman - TK+64MB + 64MB RAM
    dallyis - Upgrade
    QuietBear - 68030TK+64MB A500 Set
    Warty - Upgrade
    CapnChaos - 68030TK+64MB
    keiko - 68030TK+64MB
    Drewlio77 - 68030TK+64MB
    tbkr - 68030TK+64MB
    with best Regards,
    - 8 Bit Dreams -
    8 Bit Dreams - computer & hardware repair in Germany
  2. #2
    Jim_Oregon's Avatar
    Dec 2017
    united states
    oregon
    1 (100%)
    I am interested in one. Keep me in the loop please.
  3. #3
    Apr 2016
    Germany
    Bavaria
    42
    189 (100%)
    Quote Originally Posted by Jim_Oregon View Post
    will it be used in A500 or A2000?
    Can offer 4MB version currently, have some trouble to source parts for 64MB, so it is not tested yet..
  4. #4
    Amibayer! timtheloon's Avatar
    Apr 2015
    United Kingdom, England
    Hampshire
    163 (100%)
    Interested in 2 of your builds with 64mb
    Got too many Amigas, Think I gotta problem
  5. #5
    Hal's Avatar
    Nov 2014
    Poland
    Pomorskie
    41
    10 (100%)
    Interested in one with relocator for my A1000. Currently I've M-Tec 68020 inside, so it will be a great replacement.
  6. #6
    Niezgodka's Avatar
    Apr 2014
    USA
    East Coast
    19 (100%)
    Interested in One for A1000!
  7. #7
    Confused retro man Amibayer!
    Staff Moderator
    scrappysphinx's Avatar
    Jan 2008
    Nottingham
    35
    495 (100%)
    It's probably gonna be no, but do you reckon this will fit in the CDTV and still be able to put the lid on?
  8. #8
    a.mi.goun's Avatar
    Jan 2012
    Czech Republic
    Prague
    549 (100%)
    Interested in one (64mb).
  9. #9
    Positively negative VIP
    Amibayer!
    Justin's Avatar
    Sep 2008
    Cheltenham UK
    Cheltenham
    142 (100%)
    interested in 64mb version dependant on price
    Official Amiga Walker
    join us on Facebook
    https://www.facebook.com/groups/170601321614/
  10. #10
    Schuimpy's Avatar
    Dec 2014
    The Netherlands
    Mijdrecht
    45
    84 (100%)
    Interested in one + 64mb + relocator amiga 500 depending price
  1. For Sale Matze gfx card a500
    By Flare in forum Amiga
    Last Post: 30th November 2018, 14:58
  2. Closed Amiga b5000 a500/1500/2000 accelerator 68030
    By Flynnsarcade in forum Sales Archive
    Last Post: 8th February 2016, 22:53
  3. Replies: 5
    Last Post: 9th January 2016, 22:47
  4. Replies: 13
    Last Post: 9th August 2015, 20:03
  5. Replies: 9
    Last Post: 13th August 2013, 10:51
