FastRom1MB Released!
SpeedGeek
Wisconsin
FastRom1MB 1.0 for 68020/030 ©SpeedGeek 2018
INTRODUCTION:
FastRom1MB is an MMU tool which provides "Complimentary" 1MB Kickstart ROM support to the AmigaOS "CPU" command. The CPU command already remaps the Standard 512KB ROM so this tool just remaps the Extended 512KB of ROM.
FEATURES:
- Remaps 512KB Extended ROM @ $E00000
- Remaps only into available Fast RAM
- Uses ROM header detection code
- 100% assembler code
REQUIREMENTS:
- 68020 or 68030 CPU with MMU
- 1MB Kickstart ROM installed
- AmigaOS CPU command (with FASTROM enabled)
NOTES:
A3000 and A4000 systems require extra installed hardware to access the
$E00000 ROM space. This extra hardware is required to use a 1MB ROM.
Please consider the ROM vs. Fast RAM speed before remapping. If you want to speed up copy operations see the CMQ&B.txt (included).
HISTORY:
v1.0 - First release
** NEWS UPDATE **
FastRom1MB is now obsolete. FastRom2MB now provides this function:
http://eab.abime.net/showthread.php?p=1281374
Hello, I've seen a couple of releases from you here on AmiBay, they look mighty impressive, really interesting: thumbsup:
Unfortunately I don't have hardware for it... (yet)
