Filled cm8833 mk1 repair and service
roy_bates
resistance is futile!
VIP
england
birmingham
this is just for feedback purposes and clarity within the forum(as the request was in a completed post) so thought this wise to save a bit of confusion that may arise
this is for the repair and service of a cm8833 mk1 thats pretty dead basically,so far it has lopt failure is the main issue(initial inspection shows it has indeed failed)
it was dropped round to me by user rdlr72 aka,richard..nice to meet you by the way,and a new member here,welcome
as this is your first encounter here,i want to make it as pleasant as possible
ill order the parts in a while,so i think ill have to wait a few days for the parts,but im confident ill get it working again
roy
this is now working
it had lopt failure,basically the usual suspects
it has been replaced and the hot transistor,it had loads of cold solder joints etc,not much else to say,it works
ill let richard know this can be picked up anytime he wishes,again any problems let me know :)
a small update to this thread as there was a couple of concerns i needed to clear up with richard ill speak to him in pm as well as i couldnt test the ttl port at the time of repair as i didnt have or find a cable for it for some reason so i made one,so i have a concern about a possible cable issue or worse
i have tested all the ports and they do work,only one port didnt work properly during repair and it was easy to fix,but it wasnt the port that was mentioned
plus,i thought it necessary to adjust the electron guns slightly as green was a bit more visable in the black spectrum,i think thats about it
