I recently bought a small Amiga bundle and included was a nice and white A600... I don't need this as personally it's my least favourite Amiga :run:
Anyway i've fully tested it apart from the RF output as i'm still waiting on a cable (funny as i used to have loads of those damn cables before i chucked them :Doh:). I'm listing this item to gauge interest until i can test the RF output (maybe a couple of days).
This is what you will receive:
*Clean A600 with absolutely no yellowing anywhere!
*Clean A600 mouse with no yellowing
*Clean 25W A600 PSU with again no yellowing ;)
*Mint A600 manual
This A600 contains a rev 1.5 motherboard and Kickstart 2.05 rom (37.300 with IDE support).
Now the bad bit (maybe not that bad to some)... Most of those annoying little plastic clips/tabs inside the case along the back have snapped off, this means the back of case is a bit loose on one side. I can only assume the last owner did this as the floppy drive inside looks like a replacement (a new and shiny looking replacement :)).
I'm asking £SOLD.
You will notice in one of the photo's i'm showing the loose part of the case where the plastic tabs broke off inside (pulling it gently).
