Quote:
Originally Posted by
SaviorX
the 128 is also a 64 of course, which you can see by typing go64 at Basic7.0 screen.
First of all, congrats for getting this great machine! It is far my favorite among all commies...
Well, in addition of everything above, I would vote for the 1571 floppy drive which is the official 128 drive, double sided, double density and autoboot, if you want to run software the original way... With 1571 you will also be able to run CP/M and its applications (yes, the 128 has a Z80B inside, as well), where the 80-column mode with RGBI cable will be much useful!! 80-column looks nice on a 1084 and you can see it by pressing the key/switch on the upper row of the 128 and also switching to TTL RGB on 1084! It also needs a reset on the 128 to display 80 columns, both 40 and 80 col. modes CANNOT be displayed simultaneously!
AFAIR all 1084 monitors were originally coming with both (40 and 80 column) cables, except of the amiga-oriented RGB cable, for use especially with the 128! So if you still have around 2 weird cables that came along with your 1084, that's what you need!
In C64 mode (it can be achieved also by holding down the C= key while switching on or resetting), the 1571 works like a 1541 (the older one, SS/SD, for the 64)...
As for a mouse, REU, GEOS and so on, they are least usable!
If you want to spend some extra bucks on the C128 (for "real" use with disks etc.), go for a XE1541 cable on ebay (or DIY), and also for a Datel Action Replay VI cartridge, it's really good!
If you just want to play games the fast way, go for MMC64 or something equivalent...
Good luck with your new baby, you'll love it!!!
:thumbsup:
