Received my TF536 + relocator today, thanks. Leaving feedback
Interested. Will send PM
Interested as well. Will PM
Hi guys, I think I have contacted everybody. Please let me know if I skipped someone.
Hello! Getting around to flashing the tf535 for the a2000 fix. Confirming the firmware on the exxos forum is the newest (r2 from 8/2). Got it from there as github tf area has been largely deleted of recent binaries by stephen. Also confirming you need to have it in the amiga and powered up while connected to the xilinx platform cable. I see a pwr2 connector on the board and wondering if I can use that instead at 5v? I could probably figure out the jtag1 header but can you confirm what port on the xilinx programmer plugs into each jtag pin also? Dont want to mess it up. Thanks for any info.
Yes, leave the card plugged and the Amiga powered on while reflashing. You can power the card using the pwr header also, but i think it’s easier to leave it plugged into the Amiga instead.
I confirm the RC2 is the latest fw.
Use the whole cable with the programmer, not the one that’s separated into individual pins. I will pm you the pic of how it plugs in since I can’t upload it here due to file size restrictions.
Shipped to m0c's friend and netsurge
Payment sent - thanks.
alen please put me down for another TF536 with A2000 updated firmware.
Hello I did get both units flashed. Until now not much time to use these. Im testing heavily today. Something I discovered about both my tf536 units.
Fyi these are not complaints :) just help for others
solved: after a500 boots the unit would run for 1min then crash. Next reboot (powercycle each time) runs for 30sec then crash. Next power cycle would be flashing power light immediately. This seemed to be a heat issue because it gets worse over time so After about 1hr of troubleshooting I found when I stick a heat sink on the CPLD its 100% stable. Remove the heat sink and starts crashing again. This happens on both my cards. No problem! Easy fix!
Thank you for building these cards
