Interested in card plus relocator with shipping to Germany, will send PM :)
Interested in another. Sending PM
Shipped to gmcn. Thanks!
Hi does this work with A500 Rev5? :)
Card arrived today and it seems to be working. The IDE port is quite picky though. You do write one specific CF adapter which I did not have and after going through a 16GB DOM, a (different) CF adapter, a buffered IDE interface, I had success with just an SD adapter board. It didn't work with a 10cm cable however, but with a 5cm cable it booted. Speed was horrible though, only 650kb/s, but after installing mmulib and running mufastrom it reached a must more respectable 3.5MB/s which I think is what can be expected here.
Just thought I'd give others some tips in case they have similar problems getting it to boot.
I notice that the silkscreen has printing that suggests it can also be configured with a buffered IDE interface. Is this an option that is working and will that improve compatibility?
Otherwise it seems to be running stable and all 64MB made it here from Canada so feedback will be incoming soon. :)
Yes, the IDE is a bit picky which is why I give you the heads up beforehand on how to maximize performance. :)
I have noticed the devices I tried it with tend to fall into three categories (all assume you are copying ROM into fast ram):
1) 6.5 Mb/s reported with Sysinfo - for example the "blue and white" 8gb CF card from ebay/amazon.
2) 3.5 Mb/s reported with Sysinfo - that seems to be the one you have
3) Less than 600 kb/s reported with Sysinfo, for example with some (but not all) Memory Partner 8GB blue cards (some actually fall into the 1st category).
The buffered IDE is an option to use long cables but it has been reported not to work with the A2000 fixed firmware so I haven't built any with this option, so it's better to use an external buffer (for example those made for the A600/A1200).
Kingston 4GB and Sandisk 16 GB cards also seem to go full speed for me.
I've soldered this adaptor for a 27C160 EPROM:
https://www.pcbway.com/project/share...ickswitch.html
It doesn't take more space than the original Kickstart socket + ROM. The author offered the PCB for 2 Euro last year on https://www.ebay-kleinanzeigen.de
Even though there's no current offer the Gerber files are available. (I think a PCB service from China will make these PCBs for 2 Euro or less.)
Are you sure about this one? I did manage to find one of the adapters that you specify and I also had one of those 8GB blue and white cards from ebay. It is also only about 3.3MB/s. There is a common problem with SysInfo that it tends to report 6,553,500 bytes/s or 3,276,700 bytes/s for fast drives. Notice the nice 'round' values (2^16 x 100). If the measurement finishes immediately then the measurement is wrong. I think it is a kind of division by zero that causes it to fail.
As long as it’s not too tall it should be ok.
Oh, sysinfo is garbage, absolutely. These should really be measured with a real benchmarking tool like diskspeed.
All I am saying is the three categories I’ve noticed and the blue and white cards seem the speediest. I have ordered some SD to CF adapters to try, we will see how they perform.
