CF / WHDLoad Issue on my new A600
Hi folks,
:help:
Could one of you guru types pass on some of your knowledge on CF cards please?
I've got a new A600 (from here of course). Great wee machine it is too :thumbsup: Problem I'm having is that WHDLoad games won't run from the CF. Getting all sorts of weird errors. Everything from possible corruption of the files to processor / ram errors.
Here's how I have set it up:
Used my PC and WINUAE to create the hard drive directly on to the 1gb CF in my card reader.
My WinUAE setup was a mirror of my A600 (3.1 rom, 2mb Chip, 2mb Fast).
The CF is partitioned as 250mb DH0 (system) and 750mb DH1 (work) and I installed WB3.1 on to it. Installed WHDLoad 16.9 (with my registered key of course). Copied the relevant system ROM's into the DEVS folder so that I don't get problems with Kickstart versions and that should have been job done.
Copied some full WHDLoad (non AGA of course) games onto my work partition. Tried to run them and that's when they look like they are working, screen goes black and then instead of the game I get some error or other.
This is the same on the actual A600 or in WinUAE.
Now - when I launch the WinUAE config that I created - enable my PC hard drive and run the SAME WHDLoad game from my PC's hard drive instead of the CF - it works fine! Every game, every time.
Any ideas? I've tried a different CF too with the same result.
I did see something about Max Transfer rate possibly being an issue and I've tried to change this in HDTools to 0x1FE00 but it won't let me change it (unless I'm doing it wrong?). Don't know if that's the problem anyway though, hence why I'm calling on my good friends here at Amibay to help :bowdown:
Cheers
John
