6 Attachment(s)
Commodore 1581 drive mainboard kit replica.
PuppetmasterCommodore 1581 drive mainboard kit replica.
Attachment 168170Attachment 168174Attachment 168171Attachment 168172Attachment 168173Attachment 168169
The card is a 1:1 copy of the original 1581 card, I only added the possibility of mounting a double kernal (for example normal / jiffydos) for which a jumper is provided for selection or any switch. I only supply the standard kernal.
The kit includes all electronic components, even the board and the LEDs for the front panel.
Not included: the drive (any Amiga drive or PC modified for Amiga can be used), the flat 34pin cable and the power supply cable of the drive.
In addition, the power supply is also required (dual 12v, 5v but most drives run on 5 volts without needing 12 volts). You can use the one from 1541-II or easily adapt one.
Since you may already have the MOS 8520, as well as the CPU, the Floppy drive controller (it can be taken from a broken 1571 for example or from an Atari ST or other sources) so I also provided a KIT without these 3 components.
Some chips (for obvious reasons not new because they are obsolete, such as the MOS8520, eprom, etc.) may have aesthetic signs that do not absolutely affect their operation.
The card is perfectly compatible with the original case, if you have one. Or you can print the case in 3d (like the one in the picture, obviously not supplied but you can contact me after purchase if you need one or if you need STL files)
The purchase options are:
Full kit € 99,00
Full kit except (MOS 8520, CPU and Floppy Drive Controller) € 69,00
Kit assembled and tested € 139.00
(It is not possible to supply kit configurations other than those listed)
EU Tracked shipping € 12,90
USA Tracked Shipping € 18,90
Paypal payment (goods and services +6% fees, only for assembled kit) or bank transfer.
SOLD to bulpper (1x)
SOLD to guibrush (1x)
SOLD to Puppetmaster (2x)
SOLD to comraider (1x)
SOLD to XLV2K (1x)
OUT OF STOCK (for now)!
Due to the global shortage of electronic components and the new European VAT regulation (effective July 1st), prices may experience further increases in the near future.
