POS A4k about to be obliterated
I am starting to remember why I left the Amiga scene for a few years...
No matter how much time and money you spend on them, they always seem to play up.
Case in point. I purchased a vgc a4000. Before even attempting to use (besides playing around to make sure it all works) I stripped it down and had the psu replaced with a 350w ATX PSU (All voltages well within allowed ranges). I had the motherboard fitted with all new caps, with a new clock battery, new kickstart roms. Daughterboard had all caps replaced.
Cyberstorm card, Cybervision 64 - everything was given the same treatment.
Even the audio op chips on the a4k were replaced, just to be sure.
After all this you would expect it to be a nice system?
Well no. It ran well for about two days. Then it would refuse to boot... after half a dozen resets would again boot (HD checked in another system - perfectly fine). Then it would occasionally give a brief yellow screen... then not do it again for two days!
Sometimes it would continually reset itself, showing the green screen and playing the little Deneb ditty.
Then it will run for hours without a problem.
Oh, and for some reason, when running Payback it will continually put up the options screen and then exit back to the game over and over - as if the ECS key is stuck....
...but it does not do this at any other time. I have checked every key on the kb and they all function perfectly - including the ECS.
I have pulled it down, and put it back up so many times I have just had enough.
ANY goddamn ideas when ELSE needs to be done on an a4k in order for it to just RUN? Is black magic involved? Animal sacrifice?
Oh, I forgot. Sometimes it will boot to wb and then put up recoverable alert after recoverable alert. Other times it will boot and then freeze as soon as the right mouse button is pressed.
Then it will run AmigaMark for hours with no problems. Then other times when you run it it will crash within 5 minutes.
