Amiga 1200 and RAM expansion problems
Hello, I've been a member for a while, but I haven't posted anything in the forums other than interest in buying things :P.
So I'm presented with a problem now and since there a handful of people here are Amiga nuts(in a good way :D) I thought I'd share it with ya.
So I own a german Amiga 1200 with board revision 1D4 and Kickstart 3.0. The classic :D. Now the thing is, this Amiga works fine as it is. But I hate floppies and the reason I had got an A1200 was to install WHDLoad and never look back! So I had a friend give me an imagefile of his HD which has tons of WHDLoad games and I loaded it on an SD card, then put the card on an IDE to SD adapter and then straight to the Amiga. It worked fine, but of course you can't go far with 2MBs of RAM ;). Some games worked, like Turrican 2. Agony produced this weird kind of thing where the sound came out garbled and f****d up, at the very first scene, with the whole high resolution gray background thingy. After that it just crashed. It did work fine on WinUAE, but I wasn't really worried.
So I got a RAM expansion after a while, with the memory being onchip. I put it and it produced all kinds of weird problems. It would corrupt the disk and make Workbench crazy about checksum errors, games would get stuck at the start or not load at all giving me a memory address problem and others even went as far as to make the Amiga go off sync:wooha:.
Games that worked fine before didn't work with the extra RAM. It was recognised correctly on the Workbench though.
The obvious culprit is the memory. So I had a friend lend me one of his own. It produced the same errors! He also gave me a diagnostic tool on a floppy with some memory test, but it passed the test successfully 20 times! Somewhere around then, I found out another weird problem when the RAM board was installed. Some floppies would get stuck when being accessed! For example, Benefactor would hang when loading the first level. The floppy just stopped accessing the disk, but you could hear the drive spinning! So I was under the impression, that maybe the PSU had died. I tried with another one and although that problem disappeared, the rest persisted.
I finally gave up. I'm pretty sure it is the motherboard now, but if there are any solutions to this or if anybody has another idea I'd like to hear it. :lol:
