Can you damage an a4k by...
Plugging in a Buster chip the wrong way? :)
No I didn't, but a friend of mine who should know better did. The machine ran for about 2-3 minutes (at a blank screen) before I noticed the problem. He had plugged the Buster chip in (it had been out to clean the contacts) 90 degrees off its correct orientation.
A couple of logic ICs got hot, but not "super hot". When I found the problem I reinstalled the buster and the logic ICs no longer get hot.
No damage APPEARS to have been done, but my question is, CAN this damage an a4k mb or the Buster chip? Or is it just one of those bungles you can usually walk away from unscathed?
