I need this drive to replace another i have. Sorry i had. Because decide to leave this world yesterday.
Thanks for reading.
Thanks for reading.
I have a 19gb or a 30gb drive, both work in a 1200 fine.
So you have one 19gb and one 30gb total 2 drives ? Or one of them ? How much do you want for them ?
2 seperate drives one is 19gb other is 30gb, both tested fine and worked in my 1200.
did you want both? if so we could do a trade for the 2 30 pin simms you're offering.
OK. I'm in for the trade. Also looking for 2.5 drives 1GB and 2GB. Pack them very carefully and gimme a quote for them signed for.
Also gimme some details about them. RPM,Brand ?
They are both IBM deskstar 5400RPM drives.
Will obtain a price Monday morning as i'm away for the weekend.
Seaside - I've got a 30gb 2.5" but that's probably overkill for what you're after?
Could you not just use any drive and make a 2GB partition??
I want the drives to get rid off the noisy 3.5 (WDC,Maxtor and others in my PIII Slot 1 Systems)
So it's fine. How much do you want ? Brand ? RPM ? It's noisy ?
---------- Post added at 00:20 ---------- Previous post was at 00:18 ----------
I'm looking 1GB or 2GB because i'm planning to install them in my 486 system.
A)I will get rid off the noisy 850MB + 1.3GB 3.5 ones i have now
B)Dos 6.22 which is FAT16 does not support drives larger than 2GB while has limitation.
C)I don't like partitions and i never use them in my life. They slow down MECHANICAL drives. Flash Drives and related products do not suffer from this as the access time is almost zero.
---------- Post added at 00:22 ---------- Previous post was at 00:20 ----------
Forgot to ask we are talking about 2.5 LAPTOP drives not 3.5. Right ? They are noisy ?
