6 Attachment(s)
CV860A with 533mhz via cpu
hi folks i have a
CV860A-3R53 mobo 3x netport
533mhz via cpu
256 mb ram
no hardrive or cf card
with 12v power supply @4.2a
Processor:
Supports VIA C3/EDEN 376 PIN EBGA type
Front Side Bus 100/133 MHz
VIA Eden series Processor 400/533/667 MHz.
Lowest Voltage:
Power consumption 400MHz:3W
Power consumption 533/667MHz: 5W
Integrated full-speed 192KB L1/L2 cache.
133MHz Front side bus.
Advanced multimedia instruction set for MMX ,3Dnow
System Chipset list:
1.MB chipset : VIA VT8601A and VT82C686B
2.VGA :VT8601A Integrated Trident graphics
3.Sound :Realtek ALC 201A AC97 SOUND
4.LAN :MAX 3*10/100Mbps LAN( Option Realtek or Intel )
Memory :
Supports PC 133/100 SDRAM DIMM
One DIMM socket up to 512MB (32M x N)
Graphic:
Integrated graphics controller with VT8601A Trident VGA.
64-bit single cycle 2D/3D graphic engine
supports 2M to 8Mbyte of frame buffer
Extended screen resolutions up to 1600x1200
Sound :
AC97 2.1 compliant
DC 12V in :
On board power convert for DC 12V in to
system +3.3v/+12v/+5v
Front Panel port:
One power switch for power on
One power LED
One HDD LED
One LAN LED
One Line out
One MIC in
One USB port
Back Panel Connectors:
One DC 12V in power jack
PS/2 Connector for PS2 KB and PS2 MS
2 * USB ports
1~3 * LAN ports
Storage:
One 40 pin for DOM
One 44 pin for DOM or 2.5" Slim HDD
One CF card Socket
One DOC (Disk On Chip) Socket
One 4 pin (2.54mm) USB connector
One 50 pin Compact Flash Disk socket
BIOS:
Award BIOS
Dimension:
200 x 150 mm
working fine with all ports and connectors
www.xrousse.org/shared/CV860A-manual-1.pdf
looking for £40 was100 inclusive of postage uk only
thanks for looking
