Help This Clot Wire a Button to the HxC Floppy Emulator
Hey peeps,
I need some help for tonights project, I want to solder a 'push to make' button for the 'Button Select' as this will allow me to reset the HxC and I'll be able, at least for now to use it without the screen.
I've got jumper pins to solder in place, which I assume is the best method here and then use a cable with header plug soldered to the switch?
Only thing confusing me here is that there is only one pinout per button, so where do I solder the other side of the cable?
Any help appreciated :)
Steve.
http://i294.photobucket.com/albums/m.../hxcbutton.jpg
