EveDrive MD: Group Buy (UK/EU)
Hello there my fellow AmiBay'ers,
A while back I had a few friends say they would be interested in obtaining an EverDrive MD for their Sega MegadDrive, 32x and Sega Master System needs.
This is a fantastic all - in one solution for the sega MD/MCD/32x oweners that even allows you to load and run Master System titles! I have been looking for one of these for some time as it would be great for the retro-shows (as well as curry night with the guys ;) =D
http://krikzz.com/res/everdrive-md/_...ive-md-top.jpg
http://krikzz.com/res/everdrive-md/_...ive-md-bot.jpg
Features:Flash cart for SEGA megadrive/genesis and nomad systems
- all SEGA megadrive/genesis games supported, except virtua racing
- Super Street Fighter II supported!
- most SEGA maser system games supported.
- 32x games supported
- SEGA-CD bios loading
- hardware megakey
- 32kb FRAM for game saves keep. FRAM it is some like SRAM, but this memory not need battery supply for data keeping
- save ram data can be stored or loaded from SD card
- saves available for megadrive/genesis and master system games
- SD/MMC cards support.
- FAT16 support. 2GB max partition size
- flashed game will stay in memory after power off. so no need to choice and reflash game after each reset or power off
- connection to PC and any additional software/drivers is not required
- SPI port. usually it used for SD cards reading, but can be used for some other action. it can be used for communication with micro controllers, for example
- module system (you-tube)
- GameGenie codes is supported
- Supported SD/MMC size 2GB max
You would need to provide an SD card and a case for the unit if you want to. I have received an email from retrogate and the postages 1 - 5 units are the same $4 usd. I may ask for a higher-insured delivery for more than one item.
The cost of these units is approximately £45 for 1 unit (not including postages), I am sure with a big enough order there could be some reduction in that.
So here is a thread for us to organize a group buy for the EU/UK members.
There is usually quite a limited stock, so please list your interest over the following week, from here and we can see what deals we can get =)
thanks for reading
Z
