Ram problem on apollo 3060
Hi
I have an apollo 3060 card that not recognized the simm ram, i have tested many modules of various size from 4 mb to 32 mb but the result is the same. I have test the card in my A4000d and in the motherboard of a friend (always A4000d). I tried to extract the 3 mach chip, clean the pin with contact cleaner and reintegrated in their place but none is changed.
The 68060 (rev 1) work fine and the card work at 50 mhz (no overclocking), i have also test to change the oscillator with one at 40 mhz to see if something changed but also this test is failed.
Anyone as any idea?
Or someone can repair this card?
Massimo
