5 Attachment(s)
Another A4000 in need of help
Hello all :-)
I received another A4000 motherboard from EBay today.
It didn't cost very much so I thought I would take a chance.
As expected the board does not work (was sold as unknown) :-(
When plugged in all I get is a black screen no caps light flash or anything, at least my tv recognises it at 50hz PAL.
The board looks like it has been re caped as it has lots of small square caps in place of the more normal cylinder shaped ones.
It has also had the battery removed before it caused any damage however there is a small component soldered between D178 and the Ricoh RTC chip (see images) which I am unsure about.
Some of the jumpers at J100 where set to an external clock before I set them back to the same as my working A4000 EC030 (thanks hikey).
The main area of concern is under the kickstart chips. I have looked with a magnifying glass and a couple of tracks have been fixed with a strand of wire.
The kickstart chips are v3.0 but do not look like my original v3.0 ones.
There is also some strange cap soldering around C317 which i am unsure about.
Last but not leased I have spotted an extra wire near the audio outputs (see pictures)
Any help would be great as I do not want to bin the board.
I would much rather getting it fixed / swapped.
Thanks in advance
James
