1 Attachment(s)
Overdrive PCMCIA Harddisk for A600/A1200
Hi People,
I have an Overdrive Archos PCMCIA Hard disk for A600/A1200 for sale with manual that I found online and printed out and original AQInstall floppy. The system boots in about 5 seconds from power on for me.
There is an install of Workbench 3.1 on the drive but it's sold as blank and you should wipe it and start again.
This can be used along-side an internal hard disk without problem. Be aware that some memory upgrades >4MB will block the PCMCIA port. In this case you can either remove the memory card completely or reduce the memeory to 4MB or boot workbench and run NoFastMem then run the app on CC0: to make the drive appear.
It has a built in 40 GB harddisk which I have been told can be used to its full potential with the SFS or PFS file systems.
It is all working perfectly and I have attached a picture.
Looking for £30 + postage. Payment by paypal, buyer covers any paypal costs.
Postage :
Item weighs 1.2 Kg size 29cm X 18cm X 10cm
If you can find a courier where the postage is cheaper then give me a shout and I'll use them instead.
I will use Royal Mail as the courier as they seem to be the cheapest:
UK mainland: £5.67
Europe: £12.51
USA: £14.25
http://www.amibay.com/attachment.php...9&d=1308514285
