Need the mouse pcb of a revision 2B amiga 1200 motherboard, working or not, cheapest possible :).
Thanks.
Thanks.
Does it absolutely need to be the PCB extension?
You could easily make yourself a suitable cable instead, if all that's required is the mouse port (somewhat like the 1D.4 revision, with the added slight difficulty that it's a female connector on the 2B). I'd estimate the cost to be around 3-4 EUR.
I assume you mean http://i54.tinypic.com/14ik3mo.jpg
Heres a pic of a 2B board I believe... The pins appear to be on the mouseport expansion part, and the connector is a bit different from the ones that use the cable. It may be a bit awkward to make one if hes not the tinkering kind...
Ah thanks Skel, that gets my point across nicely. :thumbsup:
@skellions
Is that's what i need.
@all
I made one cable, but it's not the same ;).
^ good a reason as any... only the original... only amiga... can make it happen ;)
want this work too http://cgi.ebay.co.uk/Amiga-USB-Mous...ht_3460wt_1059
it comes with gender changer too ie female to male
Yeah don't buy that it's not great :) I know
lol i allready have but cant use on new mainboard has no mouse header all on pcb, so might sell it now
