8 Attachment(s)
C64 keyboard clean / repair
hello all,
My C64 has a damaged CBM key , so i have acquired another but it doesn't work very at all. Some keys work and some dont, also its pretty filthy..
So time to strip the C64 , clean the keyboard and swap the keyboards over so my C64 keyboard has all the keys.
So i stripped my c64, dismantled the keyboard - you have to unsolder the shift lock key to remove the base of the keyboard.
On inspection most of the contacts are dull and dirty , so they are gentle cleaned with a sponge polishing block then wiped over with cleaner.
Each pad on the keys was cleaned with cleaner as well.
Okay all good..so a quick rebuild and solder the key lock back on and pop a few screws in to test!
yay ...success , all the keys work. So now i cleaned the keys in soapy water and blew dry with an air compressor.
Refit all the tiny screws i left out and refit in the C64 top cover.
Finally refit the cover and test..
All good - a fully working C64 again. :-)
All very easy but worth while i think .
