As stated, I am looking for a 8372AB 318069-03 (2mb PAL Agnus for A3000T).
Hopefully I will have luck :)
Mate, the Agnus for A3000/3kT is universal. There no such thing as PAL or NTSC for A3000.
Only A500+ and A600 have a tied to PAL or NTSC 2Mb Agnus.
are you sure?
From www.amiga-hardware.com:
Chip Name Chip Number Part Number Used In
Agnus (512K) 8361 252125-01 A1000 (NTSC), A2000A (NTSC)
Agnus (512K) 8361 R3
Agnus (512K) 8367 252362-01 A1000 (PAL), A2000A (PAL)
Agnus (512K) 8370 318070-01 A500 (NTSC), A2000 (NTSC)
Agnus (512K) 8371 318071-01 A500 (PAL), A2000 (PAL)
Agnus (1MB) 8372A 318069-02 A500 (PAL), A2000 (PAL/NTSC)
Agnus (1MB) 8372A 318069-029 A500 (PAL), A2000 (PAL/NTSC)
Agnus (2MB) 8372AB 318069-03 A3000 (PAL), A3000T (PAL) (came after 8375B)
Agnus (2MB) 8372AB 318069-039 A3000 (NTSC)
Agnus (2MB) 8372B 318069-03 MegAChip (NTSC)
Agnus (2MB) 8375 R0 318069-18 A500+ (PAL), A600 (PAL)
Agnus (2MB) 8375 318069-10 A600 (PAL)
Agnus (2MB) 8375 R2 318069-10 A500+ (PAL), A600 (PAL)
Agnus (2MB) 8375 318069-11 A600 (NTSC), MegAChip (NTSC), Mini Megi Chip (NTSC)
Agnus (2MB) 8375 R2 318069-11 Mini Mega Chip (NTSC)
Agnus (2MB) 8375 318069-17 A500 (NTSC), A2000 (NTSC)
Agnus (2MB) 8375 318069-19 A3000 (NTSC), A3000T (NTSC)
Agnus (2MB) 8375 390544-01 A500+ (PAL), A600 (PAL)
Agnus (2MB) 8375 390544-02 A500+ (NTSC), A600 (NTSC)
If you are right though, how do I switch my A3000T from NTSC to PAL (I don't have any of the user guides :( )
I have the following NOS Agnus chips for you (all are 8375):
390544-01
318069-16
318069-18
318069-10
Hopefully the forum gurus will know if any of them is compatible with your system..
@BLTCON0: all 8375 (no exception) will not work in the A3000(T). 8375 2Mb Agnus have shifted pins, so they only are useful in A600/500+ and latest A2000 boards (IIRC, only the 6.3 revision).
I still searching for an affordable 8372AB to test it in one rev6 A500 to validate the 2Mb hack on the A500.
Using the A3000 Agnus on an 8372A A2000 (rev 6) will work, but you must add "manually" the missing A21 trace to the board prior to upgrade the amount of RAM.
This procedure is well described and Nathan (aka Amigamaniac) & Abbraxious (Steven) can tell more about it.
Excellent info, too bad I don't have an A2000.
As for the A500 2 MB Chip RAM guide, is this one you're talking about? It mentions a 8372B and not an 8372AB Agnus though :huh: They were both used on A3000s but were they fully interchangeable? There actually was a somewhat logically priced 8372B on ebay recently.
