A4000 Buying/Upgrade Advice =D
Hey Ya'll,
I just typed this up for a friend at EAB, I thought it would be useful here too as a FAQ if you like and peeps could add to it with more info :thumbsup:
So here we go!
Firstly, great choice the A4000 is an awesome machine. Just be sure to get one without battery damage if possible, i.e if the battery has already been replaced thats a good thing. Worst comes to worst then there is a chap going by the name of Hikey on these boards/Amibay, etc who refurbs A4k boards to a very high standard.
Right, lets talk about upgrades. Firstly CPU :ninja:
The base model has an EC030 CPU, and the Motherboard can take 4x 4mb Simms for a maximum of 16mb Fast Ram. The first upgrade to this would be an A3640 which is an 040 CPU clocked at 25mhz and gives a nice boost to the A4000. These however do not give the option of extra Ram and as such the only way to expand Ram further is a hens teeth x-calibur board or ZorroIII Ram such as ZorRam/DKB3128 or Z3 Fastlane which also gives you Fast SCSI.
Next up are the CPU expansions that include Fast Ram as an option and this is what I'd go for as the Fast Ram on the CPU is much faster than ZIII or Motherboard Ram.
Most come in 040 or 060 the Apollo 4040/4060 is a nice option, I found both these cards very fast and the Memory interaction seems to be much faster then the DCE cards. They take up to 128mb Ram (4x 32mb) :)
Another 040 option would be the Warp Engine, it has faster SCSI than the Apollo and comes at around the same price, of course this also takes up to 128mb.
Now, these are the most saught after, the Cyberstorm Cards. I'm lucky enough to own a MkII + SCSI Kit and it is indeed a very nice card and the SCSI makes a nice boost to my system. But as I said the Apollo at least to me seems a little faster. Anyway the choice you have here are the CSMkI which again all these have 040/060 options depending on budget and take up to 128mb Ram (4x 32mb) The MkI has seperate boards for Ram/SCSI and will be the cheapest of the Cyberstorms.
The CSMkII has the Simm Sockets on the single board, much like the Apollo and has the option as I said before of adding SCSI by seperate adapter. It will cost you a little more than the MkI ;)
The Holy Grail would be the CSMkIII/CSPPC these are the same board, the MkIII is just without the PPC chip so they both have UW SCSI on board and a PCI connector for the CyberVision Graphics card, these will set you back some serious money :o
Ok, I think that covers us for CPU and would be your biggest financial outlay.
Next up you have the choice of keeping the system ZorroIII and getting Zorro RTG Cards like the PicassoIV or CyberVision 64/3D plus many others
There are also Zorro Network Cards, Sounds Card, etc available such as the Toccata 16bit Soundcard and X-Surf Network Cards.
Or you can go PCI with a Mediator/Prometheous or the hens teeth G-Rex :bowdown: (The G-Rex requires a CSMkIII/CSPPC)
The initial outlay on the PCI Bus will be re-couped with cheaper PCI Cards such as graphics, sound and networking. Plus the Mediator PCI boards still have Zorro slots & AFAIK you can still use the Zorro slots with the other options, however beware the Prometheous is quite messy as you have to use PCI risers and extenders. The Mediator replaces the whole daughter board.
Finally for every A4000 I'd suggest a Deneb USB, this really is a must have addition to any A4k project. Fast USB 2.0 will open a whole new world!
Next up OS
Well if you have upgraded to an 040 or above and have 3.1 Roms (or a Deneb for loading custom kickstart modules) I'd suggest OS3.9 and the version I have is Classic Workbench OS3.9
If you have a basic 030 A4000 without RTG look at the lower end CWB packs.
But I'm guessing you'll be adding RTG and the likes to your A4000 and the CWB OS3.9 pack lends its self well to this, you just need to install the drivers for your RTG card and you'll be enjoying 24bit workbench in screen modes like 1024x768 :cool:
With RTG comes the issue of switching between RTG screens and native screens (for games and such) the most simple option would be a Monitor switch box or LCD TV with Scart/VGA inputs.
I wont go into too much detail but there are options such as Indivision AGA and RTG cards with passthrough or built in/optional Scan Doublers. The PicassoIV for example is a true one monitor solution as it has built in SD/FF
The other option would be a Video Slot Scan Doubler or DCE Flicker/Scan magic. These options are not always 24bit though and you may loose colours with AGA outputs! So check before you buy.
Compatibility wise we have WHDLoad for our older games so on most setups you'll be covered here, 040's tend to have a few more issues with games than the 060's and of course 030's are the best for gaming. But for fast RTG A4000 look for 040+
You can still use you A1200 with Blizzy1230 for gaming right :thumbsup:
So that leaves us with pro's and cons vs A1200T
Pro's:
A4000 is a flagship system, not a custom cased A1200
A4000 has ZorroIII (A1200T can only have ZorroII or PCI)
A4000 has the option of 16mb Motherboard Ram
Cons:
A1200 can take up to 256mb real accelerator Ram (Blizzard+SCSi Kit)
IMHO the PCI/Mediator options seems to work better on A1200
I hope that helps, if you have an questions just ask! I have two A4000 projects, I guess you've seen the posts but here are the links just in case - feel free to borrow ideas from them
http://amibay.com/showthread.php?t=7140
http://amibay.com/showthread.php?t=10442
Oh and have fun! :)
Steve.
