3 Attachment(s)
UpScope Arcade Machine issues
The owner of an UpScope Arcade Machine has contacted me to ask about a problem they are having with it.
If you don't know, the UpScope Arcade Machine is based on either an A1000 or A500 motherboard which is connected to a rom daughter board which contains the game roms, so it boots like a real arcade machine from rom chips, but is using an Amiga as its system. Quite cool.
Anyway, the owner has provided images of the motherboard to confirm it is an A1000 321049-01 rev 6 NTSC US motherboard. It is powered from an Amiga PSU. Other information he gives is that the game roms are on the daughter board, plus 3 roms on the motherboard (although he doesn't say what he means by these 3 roms, but you can see the motherboard below to get an idea).
Now the issue. He has checked the correct voltages from the power supply are fine. however when the system is booted the startup game image is perfect, but once the game has started the display is showing garbage over the game image (The third image I've attached below shows the garbage he is referring to).
So, any of you got any ideas what is causing this? What he can test?
He also mentions that he found another Amiga PCB that works halfway, but that is all he has told me.
Any questions to ask him to get more information?
