1 Attachment(s)
TurboDemoCard 2Mhz turbo for C64 (new board)
hello,
This is my second post on this nice forum. I want to introduce you my latest hardware project for C64. TDC (little) is 2Mhz speeder working with C64 new board. To use it you have to replace VIC and SID from board and put TDC in to socket. If you want to have compatibility to 100% software made for C64 you have to solder one wire to SHARP chip or leave it and use plenty of software witch use c128 mode on C64.
how it works? Check this http://www.megaupload.com/?d=3JNQTZJG
I pressed turbo button during presentation, so slow=1Mhz fast = ca.2Mhz.
Compare it with original demo from OXY.
Small info on http://wiki.projekt64.filety.pl/doku.php
TDC Little final should have:
- turbo mode with turbo switch (two diff. modes)
- DL, display list (eg. FLI without CPU use.... yes it's easy)
- dual sid (MONO)
- one channel 8-bit dac, simple design.
So what do you think about it?
