I started this some while ago but had to put it away for a while but now it's back and is almost finished.
A few years ago I built an A600 as a sort of laptop albeit very heavy in a homemade sheet steel case. It worked but was a bit flaky and rattly.
This time I decide to go for a 1200 but use a brief case as a case to make it a little more portable.
The specs of the machine are:
1D4 motherboard
Apollo 040/40 accelerator with 32Mb RAM
Eyetech SD/FF
Eyetech 4way bufferred IDE
Eyetch EZKEY keyboard adapter
Slimline CDROM with ATAPI/IDE adapter
Slimline PC(laptop) floppy with adapter with just pins 2 and 34 crossed on the cable
4Gb CF card with CF/IDE adapter for the hard drive
PCMCIA CF adapter for file transfers
PCMCIA wireless card
PCMCIA ethernet card
Shuttle PSU
Slimline PS2 keyboard
Synaptics PS2 trackpad from a dead laptop
Cocolino PS2 mouse adapter
Switchable external amiga mouse port
12" desktop LCD screen stripped out for the display with inbuilt speakers and amp
CU Amiga CDDA mixer to mix CD audio with the native audio
The mother board has been modified with the PCMCIA reset fix from aminet and the PCMCIA LED fix found on EAB courtesy of doobreynet and the modulator has been removed.
Here are a few pics,
http://i186.photobucket.com/albums/x...a/DSCF8184.jpg
This is the PSU cabling. All it has now is a standard MOLEX connector to feed to the motherboard, a floppy connector which feeds a power distribution board, a connection to the ON/OFF switch and an earth connection.
http://i186.photobucket.com/albums/x...a/DSCF8182.jpg
This is the mouse connection. The external and internal connections on the cable have the power and gnd lines switched to select either the internal track pad or the external mouse/joystick.
http://i186.photobucket.com/albums/x...a/DSCF8175.jpg
PCMCIA LED mod
http://i186.photobucket.com/albums/x...a/DSCF8185.jpg
CF card harddrive
http://i186.photobucket.com/albums/x...a/DSCF8187.jpg
Fully fitted lower case.
And a few piccies of the "finished" thing.
http://i186.photobucket.com/albums/x...a/DSCF8337.jpg
Overall shot
http://i186.photobucket.com/albums/x...a/DSCF8338.jpg
View of the keyboard and track pad. The 4 screws allow easy access to the guts of the machine.
http://i186.photobucket.com/albums/x...a/DSCF8340.jpg
Screen view. I used Bloodwych's ClassicWB OS3.9 as a starting point and then tweaked it the way I wanted it. The backdrop is a MAC backdrop which I used to create a pattern for the dock. Only problem I have is I have not found a way or removing the border from the dock. Anybody got any thoughts on whether it is possible?
http://i186.photobucket.com/albums/x...a/DSCF8342.jpg
CD and PCMCIA slot
http://i186.photobucket.com/albums/x...a/DSCF8343.jpg
Floppy and power
http://i186.photobucket.com/albums/x...a/DSCF8345.jpg
Rear connections with the external mouse / internal trackpad switch next to the mouse port
http://i186.photobucket.com/albums/x...a/DSCF8348.jpg
http://i186.photobucket.com/albums/x...a/DSCF8349.jpg
http://i186.photobucket.com/albums/x...a/DSCF8350.jpg
Some benchmarking screen shots.
It's finished for now, there are still some improvements I want to make, USB support for one and change the PSU for a battery and Pico PSU and charger cct, but that will come in due course.
Hope you like it! I do!!
