Greetings Oracle,
I hooked up my (until now perfectly working) a600 today, and the sound has gone low and crackling, and the joystick seems to be stuck up/left.
- Both failures occured at the same time.
- I have done no configuration changes to the machine
- Specs: A600 R1.5 with A601, CF card and 2mb PCMCIA SRAM
- Mouse still works, joystick tested ok in a1200
So I opened the case and found this war zone:
http://s4.postimage.org/1vitnp5d0/a600caps.jpghttp://s3.postimage.org/92c7jfyc/a600caps2.jpg
I don't know which caps are for what, but assume some of that mess explains the audio trouble.
- Do you know if any of this is causing the joystick problem as well?
- From the pictures, is there any damage not fixable by cleaning and replacing caps?
In any case, I intend to order full capacitor sets for my a600, a1200 and cd32 shortly, to avoid further havoc.
Thanks!
