Hey guys I thought of asking here as I have a strange issue with my RTC on my A4000.
My A4000 mobo has the coin battery mod with the diode from the previous owner and seems the mobo had some sort of repair that is really well performed.
First time I checked the clock was iirc 1978. I thought the battery was dead so I changed it with an new CR2032 one. I checked the voltages with my multimeter under the socket to ensure that the connections were going correctly to the mobo and fired up the Amiga.
For some strange reason the system booted with clock showing:
- January 2005, 12:06pm
When I changed the clock via Prefs:Time, the time changed just fine and everything worked... till next reboot that again showed:
LOL wtf?
OK I even used "setclock save" command and then a "setclock load" as I remember from the old days, but even then no difference.
It's not such a big deal cause I could sync via NTP once I'll have the miggy connected to the internet permanently but it's getting a bit on my nerves knowing that something isn't working as intended :)
Could it be the RTC chip screwed for some reason?
Cheers
