Mega midget racer ram
Hello knowledgable people ..
The Csa mega midget racer uses on board 512k fast ram can I remove the 4 ram chips and expand this to a larger size ? Or is this simply impossible!
I know the card has a 32bit connector but I
Do not yet have the daughter card for it.
Just a thought...
Mike :-)
in a word: no.
Those are SRAM chips which are damn fast - you can use them to shadow ROM (csa-mmr SROM) or as fast RAM (csa-mmr SRAM)
If you have no daughtercard, use them as RAM...
thanks for the info nick
If you are rich enough you can create your own SRAM board with the 4Mb (must be 32bit wide) and hook the address & data lines from the connector.
No need for clock (SRAM doesn't need it) or RAS/CAS malarkey.
Maybe
When I worked for csa, I wrote an admem program to add 2mb of sram (using qty 4 512k x8 sram chips). These chips are the same 32pin dip and were a direct replacement. I don't know if I was using a standard csa-mmr or a prototype (it looked like a regular production board). I've been trying to get a few of these sram chips to try in my csa-mmr (the one I used to write the software is long gone). The chips are about $15/ each which is too much for me just for expirementing.
joekster, very interesting!
Could I ask if you know anything about the csa-mmr utility: I'd really like to see if it could be rewritten to load a ROM from disk into the Static RAM area...?
Sort of...
It is possible to write any data you wanted to the sram. The mmr would just flip a few address bits and then the kickstart memory range would be redirected there. This remap does not survive a reboot/reset. However this presents some issues. It would be like flipping the switch on a kickstart switcher while the computer is running... There was thought of using eproms instead of sram - but the kickstart image would be the same. You can always use the 030's mmu to softkick...
I was never trusted with the source code to their utility. I would write a stand alone program and send my source code to them for inclusion in the utility.
Ah yes, it uses the MMU... I forgot about that!
The csa-mmr does not use the mmu when shaddowing kickstart to sram. It is the logic on the mmr, even an ec030 can shaddow.
But, with an mmu, you can softkick. I think the cpu command supports this.
D'oh. I read MMR as MMU :)
It would be great to know the logic so we could expand the utility a little.
Perhaps time to dig out resource or whatever state of the art currently is!
