Is my work area the worlds worst??
i have 2 pc's there running both with sides off..
the white one i use to flash 360's lock and unlock also prepair original xbox hard disks. and check drive integrity excetera (it also doubles up as a file server)
The little horrible dell thing i usualy use to browse the web and stuff.. The side is off because when i have multiple hard disks to check then they both get to work.
the little tv is for xboxes and the white pc. I have all my tools 2 soldering irons (1 is with my hot air rework station) I probably a dosen xboxes under the table and in the side compartments. (also some more in a little trolly doo dah) the long thin drawer is full of wires excetera, i have piles of bits which do have uses. and Just about enough room to work on..
if desperate i will use the dining table.
So do any of you have a worse work area or do i win??:p
http://img403.imageshack.us/img403/8...g00031p.th.jpg
http://img830.imageshack.us/img830/6...g00030l.th.jpg
http://img546.imageshack.us/img546/6273/img00035.th.jpg
http://img13.imageshack.us/img13/5642/img00032i.th.jpg
http://img171.imageshack.us/img171/8...00033pz.th.jpg
http://img406.imageshack.us/img406/1...00034ym.th.jpg
