Ok.
I've had a few problems with my Amiga, as I think some will know. I have managed to get the basic system to boot up to the purple screen every time without the accelerator in and hdd unplugged, which is good progress as far as I am concerned.
I also have the Accelerator virtually working. It may take 3 or 4 reboots, or the odd power cycle, but it does spring to life.
However, it does get a bit toastie inside there. It is running at 50mhz, and has a co-processor at equal speed. They appear to be sharing the same crystal via a kynar wire. If I do a long CPU intensive task (I recently unzipped about a gig of data), the system will crash.
So, could I just replace the 50mhz crystal with a similar 40mhz, losing a bit of speed, but gaining a bit of stability? Would I gain anything by using 2 crystals of the same value instead of the current shared setup?
The card in question is featured here in the bboah:
http://www.bboah.com/index.php?actio...965&artlang=en
Sorry for all the questions... but :bowdown:
:thumbsup:
Chinners
