FastATA 4000 MkV problems.
Hi everyone,
I have installed a FastATA 4000 MkV into my A4000 today but it's not seeing a connected HDD which I prepared last night and have been using ok on the onboard IDE. The board is displayed in the early startup screen as Working.
The IDE ribbon cable is connected to the Primary port on the FastATA and has correct polarity. The drive is set to Master and I have a CDROM set up as Slave on the same cable. I've also tried disconnecting the CDROM and using Cable Select settings. I've tried swapping positions of the devices on the cable.
Do I need to get one of those IDE port disablers to make the fastata work.
Thanks,
Ed.
