Originally Posted by
chiark
1. I wouldn't bother - leave it at 16MHz and, when appropriate, add a CPU card :D
2. As long as you're only running one card, you should be fine. I seem to remember the issues with previous busters are around running multiple cards that want to bus master. As long as you don't add a deneb, you should be fine. But I am really not sure here :D
3. No, not really. Finding newer ramseys is difficult!
4. Check the LED board - many traces have simply died on these so you might need to repair. REMOVE THE BATTERY!
5. 1 Jumper :D - J200.
If you're running an AT or ATX PSU, change tick clock source (J350)
Enjoy!
