only as text but yes
Mike
If you need an Eprom programmed, send me the code & I'll get it done for you fella....
If you want send me your existing Eprom & I will blank it & program it with the code you want FOC
TC ;)
any chance of a printout,more importantly is it allowed
Turbo 040/060: V5.60 - 17.12.96
- Written by Zuheir Urwani and Thomas Kolbe, PROFITEAM Software, Kronprinzenstr. 22, 44135 Dortmund, Germany
NęNudos.libraryJ¸ż@Turbo-System 040/060Turbo 5.668060.library»Ű S
Apollo.deviceSCSI-Apollo.deviceexpansion.libraryFileSystem.resourceH>:Profiteam!FastFileSystemtimer.device
Nucard.resourcecdstrapexpansion.library
SCSI-Apollo.deviceSCSI-Apollo.device 5.21 (25 Feb 1996 Z.Urwani & T.Kolbe)
dos.libraryexpansion.library
Softworks by Profiteam SoftwareApollo-REQ.interruptApollo-TO.interruptJ9
AT-Apollo.device
---------- Post added at 23:56 ---------- Previous post was at 23:55 ----------
thank TC but i have an Eprommmmmer here, just have to remember how to use it. Still I'm not busy at the mo..
but thank you , thats very kind of you :-)
i've put up some highlights of the code roy, nothing exciting.
cheers,im curios as to whats in the code itself.:)
---------- Post added at 23:58 ---------- Previous post was at 23:56 ----------
im looking for the part of the code that point to the memory addressing,there should be something about a 16mb block check.
the best way is download a hex editor and take a peek roy , Freeware Hex Editor XVI32 on Windows or HEX Fiend on OSX both free.
file open - Apollo.bin and bingo
---------- Post added at 00:01 ---------- Previous post was at 00:00 ----------
half of the rom is empty as far as i can tell.
Really all this is for my Apollo 1260 not this one that's been fixed so this is the wrong thread for the viewers.
For those of you watching in black & white, the brown is behind the red :-)
UPDATE to this thread.
My Apollo and this repaired Apollo are now working fully with firmware Rom 5.60 on an XC68060@66mhz 64mb ram.
its fast and error free, playing 060 demos and generally amusing itself.
The problem all along was the EC cpu. This apollo it worked just fine but in mine it would not boot without CPU cache turned off. - pointless really.
But.
The XC68060 has cured all its problems and i suspect the upgraded 5.60 boot rom has helped too.
all the best.
mike.
PS
I have a MC68060 on the way and a XC68060 so we'll see if i can hit 80mhz or so.
---------- Post added at 18:14 ---------- Previous post was at 16:33 ----------
http://youtu.be/qfzqKueXjMU
This vid is of the Apollo 1260 running at 66mhz with a geforce heaksink sat on it. it does get warm after ten mins but the heaksink keeps it nice and cool.
One odd thing about this card is occasionally it forgets it has ram ? a quick clean with ipa and reseat the ram and its fine. now it could be because I'm pulling the card in and out constantly trouble shooting thats naffing it off. don't know but its fine now..
odd.
Doom with midi instruments added.
it might be the ram jumper on the card mike,try giving it a bit of a clean and bending the pins out to make the jumper tight.
or it might be that the mach 210 needs to be re-seated as well.
its still a result though.
cheers roy , I've just done that
popped both machs out and cleaned the pins & sockets with ipa
my friend should have a super stable card here me thinks..
i think you friend will be chuft to bits,not only has he/she got it back working its also a bit faster.
are those two videos supposed to be the same mike?
opps no they were different but i was very tired yesterday.
no matter same old stuff , one was at 50mhz and one at 66mhz. Just for the owner to see it running really nothing more.
the XC does get warm at 50mhz and very warm at 66mhz. So i hope he bolts a fan on somehow.
I've supplied him with 50mhz and 66mhz crystals so he can play about with it.
