I've decided to do a spring clearout of my Amiga items hence a list for sale..
Rules:
Prices and postage: All prices are inclusive postage to Europe. Postage is un-tracked letter at buyer's risk. Europe includes all countries shown on this map - if in doubt please ask. For simplicity there is no combined postage cost (won't be much cheaper anyway).
Payment: Declare your interest here on the thread AND send a PM
Items: All items are NOS and should be fully working as to my knowledge. Unless stated all are untested. As a base rule there is no return or refund. I'll try to solve any problems with you the best I can, but I'll ask that you show you've done proper testing on the item and/or that you return it. There is no need to ask if the item is available or not - if the item IS listed, then it IS available. If the item is marked SOLD, then it's NOT available.
Feedback: Please leave feedback as per the site rules after you've received your stuff. Here is a guide how:
http://www.amibay.com/showpost.php?p=60784&postcount=3
So here we go:
Item 1: CDTV front assembly £38
Tested and fully working. Nice condition apart from a few tiny scratches (check photos) nothing serious. Replacement stock.
Item 2: CDTV video module £17
Good condition, has antenna IN, TV out and composite video out. Replacement stock.
Item 3: BASEBOARD for A1200 £7 (LAST ONE)
Add on module for Amiga 1200 that adds a real time clock and calendar. Brand new, fully boxed with manual. Coin battery needs to be replaced.
Item 4: Boot Selector for A500/A2000 £13
Allows you to choose your boot FDD (3 way switch for 3 FDD boot setup). Brand new with install guide.
Item 5: MIDI Music Master for A1000 £13
Brand new and still in protective plastic. Don't know about the contents, but I'm guessing there is at least one MIDI interface for the A1000 inside:roll:. "Free MIDI cables" is also stated on the box. Quite heavy.
Item 6: Auto Mouse/Joystick Switch £17
The box states for Amiga/Atari. Brand new, comes with a small guide. Simple to use, press fire for joystick mode and press left mouse button for mouse mode.
Item 7: CDTV LCD module £21
Front assembly LCD display module for CDTV, with connecting ribbon cables and microswitch buttons. If your display is dim or the buttons don't work on your CDTV this could be the answer. Replacement part.
Item 8: A3000 internal FDD new, boxed £44 (heavy)
Brand new and never been opened. I can open this and test it for the buyer's request after payment. The label states 3010 internal so I'm pretty sure it's an internal model.
Item 9: DATAFLYER SyQuest SCSI drive £16 SOLD
105MB Syquest SCSI internal drive for A4000/A2000. Brand new and boxed, comes with full mounting kit, screws, PSU cable and manual. Unfortunately there is no media cartridge inside.
Item 10: 86PIN Expansion Adaptor A500 £18 SOLD
Brand new. Well, hm what it says, I think this adapter allows you connect 2 expansion device to the A500, one horizontal and one vertical.
Item 11: AdRAM 560D for A500 £37
2MB RAM optional add-on module for the AdRAM 540. For A500. Quite rare - original box and manual (Danish but I will look for the English guide)
Item 12: AmiQuest PCMCIA HDD enclosure £16 SOLD
Brand new and boxed. PCMCIA HDD enclosure for adding 2.5" HDD for A600 or A1200. Comes with driver disk and install guide.
Item 13: Datel Music/MIDI Interface for C64/128 £13 SOLD
New and boxed, comes with MIDI cables and guide.
Item 14: Digital Sound Sampler with microphone C64 £17
Brand new boxed, comes with manual, software disk, microphone and cables 6.3 jacks. Looks like a quite sophisticated sound sampler and effects generator. Has echo feedback, Line output-input, mike input, trigger out. Photos here
Item 15: SCSI Controller for A1200 Dataflyer £37
New and boxed, with breakout cable and bracket, mounting screws, driver floppy (copy), and install guide. Connects to the 2.5" IDE port and prived IDE pass-through and SCSI+ connectors. Photos here
Item 16: 256K RAM expansion for A1000 £26 SOLD
Brand new and boxed with install guide. Not much to say about this, there is no rust on this - shiny new as it left the factory. Photos here
Item 17: Macro System V-Code digitizer £15
New and boxed, box and manual is a bit beat up. RGB - FBAS and Y/C coder. Can't find out much more as the manual is German only. Photos here
