Indivision MKII HDMI adapter
Hi all,
I have HDMI adapters for use with the A1200 Indivision MKII for sale $13.50 each.
http://www.kipper2k.com/amigaforsale/mkiihdmi.jpg
HDMI Adapter
For those people with the MkII indivision., this will allow you to connect the MKII indivision to this and allow you to plug in a HDMI cable from the Amiga to your HDMI capable TV/Monitor.
At present, Jens has not completed the final core for his MkII indivision adapter so only a few monitors will display HDMI. Once he releases the new cores then this will display on all monitors.
This is designed to fit neatly in your A1200 where your RF module used to sit and is secured by 2 small nuts and bolts. You can place this adapter anywhere you want using Jens supplied cable or a custom length cable i can make (further down the list).
It will also allow audio to be sent down the HDMI cable for those people that want that option. I will not add the 2 pin header unless the buyer buys a custom HDMI cable to go with this.
Here is link to a picture showing it installed where the RF modulator used to be.
http://eab.abime.net/showpost.php?p=...&postcount=999
Here is a link showing installation instructions...
http://www.kipper2k.com/amiga/audiomod/audiomod.htm
