PSX joystick adapter for Amiga/Atari
Hi All,
I have this PSX controller adapter for Amiga/Atari for sale $19.00.
New, and i have quite a few in stock
http://www.kipper2k.com/amigaforsale/psxcable.jpg
Amiga/Atari PSX controller adapter
PSX controller adapter that will work on Amiga/Atari and most other 8/16 bit retro computers that use the DB9 connector.
Can be used in mouse/joystick mode and has built in Autofire. The 2 LED's give a visual indication of the active mode. The adapter will remember current settings on power down
Thanks to Tom Kirk for allowing me to use his code and schematics to make this adapter. If you want more info you can check out his website at
http://tgkirk.110mb.com/
Red LED solid = Normal joystick mode
Red LED Blinking = Joystick autofire on
Green LED Solid = Atari mouse mode
Green LED Blinking = Amiga mouse mode
"Select" toggles joy/mouse
"Start" toggles autofire/ atari-amiga mode
apparently this will not work with the original "psx" digital controller (PlayStation1) but works fine with the dual shock controller that is associated with the PS2
If using this on an A600 you will need a joystick extension cable or my A600 mouse/joystick extender listed on my webpage ( http://kipper2k.com/amigaforsale/ ) as the case of the A600 interferes with the winged type connectors
