Wasn't too hard, the trick is just to go very. very slowly when you are pulling the membrane up off of the circuit board.
My tips:
1. When removing the keys, make sure you don't loose any of the tiny springs in the middle. If you do, the key will no longer work.
2. Go slowly on the membrane. It will be stuck on both sides of where the key clips on. If you pull too hard it will tear. Lift gently from each side until it releases. Work around the membrane from each edge so that it lifts evenly.
-(e)
If you ever decide to scrap it, please can I have dibs on some parts? :)
