Yes it works fine with SRAM and will give you a total 6mb Fast Ram (same as I'm using) :thumbsup:
You will need to remove the HDD cradle to fit the Ram expansion so you should either switch to CF (if so grab one of Kippers Cf adapters) or you will need to install the HDD vertical and find another way to secure in place (I suggest Velcro strips) :cool:
All the best!
Steve.
