hi, any news?
hi, any news?
has anybody succesfully fitted one of these in a A2000?
Hi Kipper,
My 8MB A500 module with CPU riser arrived. I get a black screen when trying to use the board with the CPU riser, but without the riser it works fine.
I also noticed my A590 is not detected when the 8MB board is plugged in at the same time.
I have 2MB installed in the A590 and tried with the jumper set to 2MB and "no memory".
Any ideas?
Cheers,
ck
@ck16
Firstly, check the riser. If one of the holes is a bit too wide, there might be a pin not making contact with the riser and nothing happens when you turn on the Amiga.
It happened to me once.
I do not have an A590 so i cannot say what the issue is, it is possible that there is a memory conflict. The 8mb fastram board uses memory at locations $200000 - $9fffff, remove the fastmem board and do a memcheck, see what memory location the A590 uses. if it uses any range between $200000 - $9fffff then there is a memory conflict and the only option would be to either remove one or the other, or possibly use a 4mb board which would use uncontested area of ram
---------- Post added at 13:42 ---------- Previous post was at 13:39 ----------
Just to let everyone know, i am back in town and i will be playing catchup this weekend on all orders/issues.If you have something outstanding and dont hear from me by Sunday lunchtime them msg me to jog my memory.
I intend on filling all requests this weekend.
Thanks to all
"I will have them available this weekend" - Kipper2k
Signing up for :
1 x A500 8mb module 49$
1 x A600 4mb module 39$
1 x A500 adapter 9,5$
:thumbsup:
Hi Kipper, just making sure you read my post. I need one a500 adapter.
Thank you.
