Hi Kipper,
I switched to a CF Card so I confirm my interest in your 4MB A600 Expansion.
Thanks.
Liviux76
Howdy!
I did a quick check on my A500 running the A590 with 2MB RAM and found the following:
$00E90000 (Size 64K) - A2091/A590
$00200000 (Size 2048K) - FAST MEMORY
I removed the RAM from the A590 and set the jumper to 0MB and it still didn't work. I don't think a 4MB RAM upgrade would work.
Maybe the A500 PSU can't handle the power drain?
I'm still having no luck with the CPU riser card. I just get a black screen. :(
Cheers,
Chris
@ck16
I tested my Kipper 8mb Ram upgrade with GVP530 and Ram disabled but it wouldn't boot (black screen)
So I guess some/many Side Car Ram/HDD expansions are not compatible at all?
@Therad resoldering pins 1-3 on my Kipper 1000 adapter has fixed it, now my A1000 has 8mb Ram and I can still use the FDD :)
Thanks for redoing the soldering Steve, For some reason the solder silkscreen messed up and those 3 pins on the board were a little arkward to get a good bead of solder on them.
Thread should be all caught up, and everyone should have a pm to acknowledge interest.
No worries, any practice I can get soldering helps :)
They were quite hard to solder, even with lots of flux and good quality silver core solder it just didn't want to stick!
Thanks for producing these items, I can't wait for some kind of IDE :thumbsup:
(built in K508+IDE FTW!) I'd buy one tomorrow :cool:
Steve.
I'd like an A500 8mb memory board if still available. PM sent.
