Payment sent, thanks!
@save2600
Hi mate :)
I've moved your posts here.
A500 - 8mb + A600 - 4mb + A500 adapter arrived yesterday :thumbsup:
Leaving feedback :)
Got my a500 adapter and all works like it should.:thumbsup:
Thanks Kipper2k
Feedback left.
Hi Kipper, finally got round to installing this in my newly recapped a600. The adaptor is working but needs to be held in place, left alone it will pop off after a few seconds, same results in both the a600 I have. I also have an ACA620, this will attach securely (unfortunately it has issues with whdload) without needing to be held. The adaptor clicks into place but never lasts long. Any ideas?
You could use a bit of hot glue, it will peel away when you want to remove the Ram board just don't glue over an IC's as they could be pulled when you try to peel off the glue.
Mine wasn't an perfect fit either but does stay in place after reseating a couple of times.
Steve.
That's an idea, would you glue to the top of the 6800? What about heat issues?
So, glue both sides, on the outside of the socket where it meets the motherboard. Just need to find some glue sticks now...
