Couple quick noob questions, first would using a supra 28 with this cause any problems? Second I heard a supra 28 works better with fast ram is this considered fast or chip ram?
Here is a picture of the 4mb/8mb +IDE board design in the a500 (Rev 6). Just to give an idea of how it fits. the CF card header is on the right side of the board and the CF card would be inserted from right to left.. No problem in closing the case with this installed. The Rev 5 (May be) the only one that would need to be relocated to the back of the Amiga.
there is a 2 wire header on the top left of the board that would be used to connect to the 2 required signals from the motherboard.
http://www.kipper2k.com/amiga/a5008mbide.jpg
Good news !:thumbsup:
Will it fit in the A1000?
Everything is autoconfig/Autoboot ??
same as older version, autoboot, autoconfig, will fit in a1000, not too sure on connectors required to obtain required signals in the A1000 for IDE. same as the CDTV, fastmem will work fine without autoboot... and manual or script to addmem.
I don't know anything on CDTV, would INT2 and OVR be available to get IDE working (I have no clue)
Read this thread for more info... http://www.students.tut.fi/~leinone3/ide/ide68k.html
For the ide in A1000, maybe this thread can help :
http://www.amibay.com/showthread.php?t=47567
I'll check it tomorrow for you. I still haven't sorted the pinouts its been shelved for a bit now. Are we talking about the 29F800s ? When did you send it so i can check my emails :).
For those people who want the non autoconfig code, if you don't have a programmer i can send you another preprogrammed chip so you have both types allowing you to swap between if you want to relocate/sell etc for a small fee ($3.50 sounds fair :)
memory still available?
i need 1x A500 8mb (or 4 mb if 8mb is not available).
bye bye
