Will there be CF HDD for Amiga 500?
Will there some Games and applications on them?:unsure:
If you have hardware that gives your A500 IDE then sure I can make you a CF that will work on it :thumbsup:
When the ACA500 is released then you could use a CF HDD on it easily, in the mean time you would need one of the IDE68k's or one of the SCSI Sidecar's with SCSI-IDE bridge. The former needs some soldering and the latter can work out quite expensive.
Some of the solutions currently on the used market have size limitations so you should do some research before buying.
Do you have any CF cards and adapter + cables left?
Perfekt. Sending PM.
@matsch
Sorry for the delay, your kit was posted today.
Received the package this friday. Works perfect. Many thanks. :)
Little bump, I only have a few of the 4gb 133x Transcend Cards at the moment however I can get any size/brand card by special order :thumbsup:
