2 Attachment(s)
A600 / A1200 recap service
@thread - as working commitments are becoming a problem i have to wind this service down to just recapping A600/A1200 - im just too busy to do repairs / upgrades / fault finding - sorry :-(
i will recap your Amiga A600 / A1200
All work is checked and the board is tested before posting back to you. All new capacitors fitted.
I can also remove the modulators if required for no extra cost.
Faults from bad capacitors.
Sound problems, rebooting, guru errors, non booting , floppy fails to work & then black screen. As well as the capacitors leaking on your amiga board and eating it away slowly.
i have plenty of caps in stock now for all Amiga's.
Systems are usually tested for a number of hours before posting back to you. (looped graphic & audio demos)
*Note
Not all faults on the Amiga are failing capacitors / power packs and other IC's fail too.
Badly leaking caps may well eat the pad away and a repair may be required but i will do this as neatly as possible.
A600 / A1200 £26 each + post
@thread
All audio caps are now non polarised ceramic 22uf type from Christmas 2012 on-.
@all (feb 2013)
I'm working long hours at the moment so repairs will take a little longer - sorry all.
Batteries removed / battery fitted too.
Ram sockets changed / added to accelerators or A4000
modulators removed.
http://youtu.be/UwJhQ5BMmtM Video of an A600 with non polarised caps and modulator removed - during a 12hr run/test
http://youtu.be/utP-D4piuGg video of a board i recapped this morning. it had poor sound and rebooting issues / stability. all ok now.
any more info please drop me a line
thanks mike.
