Hi I have these cables and chips laying around but do not know what they are for. Can you kind folk bring me up to speed please? The square chip is the same one just both sides are photographed.
Amiga parts
agnus (8371) , denise (8362) and a kickstart 315093-01 Kickstart V1.2
Amiga serial cable- image 0767.jpg/parallel cables / centronics scsi i think
not sure what the blue cables are.
@ acid did a package arrive from me today?
Top left is a motherboard & sound card header to PC joystick port. Second is a serial port header, the rest is as mjnurney said! :)
Top row, left to right; PC Joystick header, 25-pin serial port header, rest is as mjnurney says.
Bottom row, left to right; 25 to 9 pin serial cable, 68-pin external SCSI cable, parallel printer cable.
Also, as this is female to female, it's most likely a null-modem cable.
50-pin (centronics-50 to HD50)Quote:
SCSI cable (centronics-50 to DB25 (apple's unofficial SCSI connector))Quote:
parallel printer cables use centronics-36
Few more
@ mike yes cards arrived safely see pm
last two pics are parralel printer cables(25 pin d to centronics)
Thanks guys, nothing I need in that lot it seems.
http://www.amibay.com/attachment.php...5&d=1352567383
This is DB25 SCSI to 50 pins Centronic
