You have 5 slots in that SCSI unit. Can you use all 5 slots at the same time?
Can you copy data between any slot while all slot has a media?
If PCMCIA card shows up as LUN 1 I think this is ok. You may have jumpers inside the unit to change some of the unit parameters/configuration.
The unit I have here as I said before has at least 7 jumpers inside. One jumper configs split the PCMCIA port or gives it two SCSI id. What the other 6 jumpers do I will have to look into this but I do know it has nothings to do with the SCSI id.
I have just found out my unit does DMA.
