thank you or the answer, can you tell me ecxactly what kind of pico psu is needed?
how many watt and connector.
---------- Post added at 22:41 ---------- Previous post was at 22:14 ----------
anyone know where to find fat agnus 69-03?
Oh that note the GBA1000 does have an optional built in scan doubler/ flicker fixer.
---------- Post added at 21:49 ---------- Previous post was at 21:48 ----------
This depends entirely on what hard disks you intend to use. I ordered a 120 watt model and will make an adapter to fit the A1000 power supply connector. I plan to create a new back plate for a standard ATX case. I can't bring myself to kill another A1000.
for which you need the "Amber" chip i believe ?...
i received an email from someone who has lots of the 8375 agnus chip... 6 euro's each.. thoughts anyone ?
Hey kipper, I think you missed adding TSOP service for me on the list. Please do. :thumbsup:
order 3e pcb :thumbsup:
+ TSOP
Hi All,
I tried the video hybrid board i made and... it works fine :) (tested on my Rev 6a board) The original video hybrid chip was version 1 and the version 3 i made works great. The original chip was a pain to get off the motherboard as the ground pins are soldered directly to the ground plane and you need a fair bit of heat to get them off, i used chipquik and still had a problem so if you are going to attempt to salvage one take your time.
To order a board and see payment options go to the first post of this thread.
Order closing date is 2200 (CST) Wed March 13th 2013.
Link to ordering and mailing info... http://www.kipper2k.com/gb1000.html
